HPI RS4 big block upgrade?
Hello I have a HPI RS4 3 18SS Im looking into Upgrading the motor to the Savage K4.6 engine. has anybody seen this done. What problems might I come across. Any info would be great.
RE: HPI RS4 big block upgrade?
go to wolf pack radicals website they have all the conversion stuff, word of advice dotn do the conversion just get the o.s 18 tz with the recoil starter in towerhobbies
CA
the 4.6 in the rs4 sounds like a real waste of money and alot of head aches sorry
the car is just gonna drift around and then hit a curb and break
i would still like to see a video though
Ive just put a .27 into my little buggie (cyplone Pro - WRX STI). I have two onw with a team infinity 18 motor which is all over the road as it is, and i expect the 27 big block will give me more top end as the second gear at 41000 RPM should be better thatn the 30ooo RPM from the .18. - PS standard tehy come out with a .15
i wanted to put a .21 in my rs4 evo, i saw an ebay auction once with one in it, used a .21 savae engine witht eh savage mounts, only thing is that he drilled the holes in the chassis him self, whats the best size engine for wheel spins and doin loads of spins?
FL
i got the wolfpack radicals .21 conversion
you will need those mounts, stock rs4 mounts WONT WORK, plus the wolfpack are adjustable mounts so thats a +
it really isnt that hard to control unless you constantly floor it from dead stop then yeah it will just do doughnuts
i went through alot of plastic spug gears at first until I learned how to drive it, now I can FLY!!
theres is 1 more thing you have to do, I have to change my rear a-arms backwards so the .21 header could fit...its good because your wheels are further apart for better handling but no bodies will fit it right, you will have to cut the wheel well out and make it fit the newly positioned a-arms
luckily I had some extra bodies
IT IS FUN THOUGH!!!!!!
FL
where do you get them radials .21 mounts from in the uk?
you will have to contact Wolfgang about that, I dont know if he sells just the mounts, but you can ask him hes a real nice and helpful guy!!!!
[email protected]
wolfpackradicals.com
im sayin you dont need the wp radical mounts for the os .18, for anything bigger, you will
got cha!!! I misread
[email protected]
FL
do u have a problem with the engine weight at all?
how do you mean?
the .21 is heavier than a .12 or .15 also the pipe is a little more heavier
but it'll still faster even though it weights more....TRUST ME!!
how do you mean?
yea its just that people have said that the extra weight brings bad balance problems,
will these mounts work on any .15 .12 and .18 hpi or os engine?
Also why only hpi and os? cant i use them on a different .18 engine?
FL
thats not intirely true, my car really doesnt pull to any 1 side, its pretty well balanced
those people are probably the same people who from a dead stop send the car flying a WOT...
ive even seen .12, .15 & .18s that spin outta control due to the drivers inability to control it NOT balance problems....its all up to the individual I guess and their skill or practice level
at first I couldnt really control the .21 due to the power it produced but over time I got the hang of it
I remember when I bought the rs4 w/ the old school belts I couldnt really control it that well because that was my first nitro car....funny that engine was that ugly old .15fe LOLOL
so its all a learning process......
its kinda like you get into a 222hp mustang and you can drive it
then you step into a 400hp saleen, YEAH I bet at first people couldnt make the wheels lock up and would just be fishtailing all over the place, but come back in a couple of weeks and that same person will be driving the SH*T outta that saleen
FL
why not get these alum 1's http://www2.towerhobbies.com/cgi-bin...?&I=LXCLR3&P=7
they are a little better quality and have a better stronger mounting surface
but to answer your question I think those will work w/ any .12 .15 or .18 engine
thanx,
Im from the uk as i said before and im not realy looking to spend £15 on mounts just for an .18 i can get the hpi/os mounts for like £5 / $8. Does anyone know if their is any difference in the mounting sizes in the tabs from the os engines to a diff brand?
CT
Personally you can win against a .18TZ powered car easily with a weaker engine. Remember the RS4 doesn't have that tall of gears like most of todays nitro touring cars. The OS .18TZ has tons of bottom end power and slowly broadens out on top end. Therefore a taller gearing is necessary otherwise the engine will not like the gearing. Possibly it can run hot, destroy your tires, and clutch gear. Simple thing is to drop in the OS .18CVRX for $100 or less, a tuned pipe, spare plugs, and optional gearing to play with. All that for theprice of the OS .18TZ alone. Think about it..the TZ when your done will cost you $300 to get the engine, decent pipe, and gear to make it fit in the car not to mention tires that will hold upto the sheer power of that engine. I still have a video of my friends R40 with Wasp .12RE vs a Serpent 705 w/.18TZ. The serpent wasn't much faster and did slide around quite noticably. I also personally drag raced em and around the tracks. Not a challenge unless money and setup is put into the car. Just my 2cents.
HPI makes some of the tallest gears around. If you have a 2 speed, you can run down to a 37 with a 23. Unless you want to go custom, then you can go all the way up to a 26T. I run a 37/26 set up with a .21 on my RS4-2 but Ive seen it done on the RS4-3.
