threadlock problem plz help thx
last yr due to vibration of the engine, the screws attached from the bottom just come lose instantly, so i asked the staff working in hobbies shop, they told me to use the threadlock glue to put some on the screw and screw it bak in and it shoudlnt fall out. However, it works, the screw didnt come lose again but i cant get the screw out due to its tightness and that locks the whole engine up and i cant adjust anything or take it out. wat should i do
Try heating up the screw with a soldering iron- this weakens the threadlock and you should be able to remove the screw. Be sure to use a decent screwdriver of the the correct size etc, one too small will simply strip the screw head.
a soldering iron will not melt a screw.
Even if u had the screw on its own it wouldn't melt it - Its certainly not going to with all this other material around it to soak up heat
