4-tec swing at straight line
When my nitro Traxxas 4-Tec is trying to accelerate at the straight line, the car seems swing a little bit and seems not easy to handle. How to fix this. Thanks
RE: 4-tec swing at straight line
yea my 2.5r will get going about 35 and lose it everytime.. theres been alot of parking lot bashs with this but the motor is new theres a bit of play in the front end i assume this is my problem and tie rods and the sway bar kit will fix this? i have the softest tires i could find besides foam
VA
yeh just get one of these http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXLR49 , i had the same problem with mine and i purchased the sway bar set
LA
swaybars are made to make your car turn better its not going to do anything off the line.check you shocks try to get harder shock springs and some 30 or 40 wt oil.and you also need foam tires.
I am a rookie but I can tell you I installed the sway bars the second time I ran it and it improved. I had a rock lodge into my rear belt and strip it out and I replaced it and didn't reinstall the rear sway bar and I ran it and had it slipping on me, I am not sure do to the power the shocks can't handle it and it sways and the bar stablizes it or what but I know some on here say the sway bar is for cornering, it has helped my 4 tec stay straight can't beat or at least try it for the price, doesn't work at least you can say you have them. Good Luck
