RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Handling problem , bad push
Old 07-06-2006 | 10:46 AM
coony2787's Avatar
My Feedback: (33)
Default Handling problem , bad push
I was wondering if any of you now how to stop a car from pushing in the corners. My car is a Tamiya tgx 1/8th scale car. You have to let of the gas completely to get the car to turn normally. Or else you can stay on the throttle and it is like the front end is drifting in the turns. It's kinda kewl but it is murder on tires. The front and rear diffs are open on this car. I'am outa things to try. Any help would be appreciated.
Chad
Old 07-06-2006 | 01:21 PM
mattnin's Avatar
Default RE: Handling problem , bad push
Try using a lighter shock oil and a lighter spring in the front of the car. If you can, lower the ride height more in the front too. You might want to take some angle out of your front camber links too. You can also lengthen the wheelbase.
