Little help w/NTC3....
Just got a used NTC3 looks pretty good, only thing is that spur gears are a bit worn, is there a number that it should be reached in teeth, what is the difference in color as to wich spur gear to use... 48t, 52t 50t ??? I'm a little confused....
1 Post
RE: Little help w/NTC3....
Bit difficult to understand what you're asking. Less teeth on the spur = faster acceleration, lower top speed. More teeth and you get the opposite. Not sure what the colour has to do with anything [sm=confused.gif]
If you search for an ntc3 manual it should tell you which spur gear (no. of teeth) comes as standard - that would be a good place to start
Yeah, I was talking about the gears that are on the engine shaft, you know, green, purple, black... but I got it now, thanks, by the way could you tell me the benifit of having a one way diff assembly and does it have to be in the front diff, or could it be in the back?? thanks.
1 Post
I've never used one myself, but 1-ways are generally used to give more on-power steering. They are only ever used in the front diff, in the rear they probably wouldn't give you ANY steering... Mostly used for high-traction surfaces when racing i think. They'll also remove 2 braking wheels, so stopping becomes a bit more difficult....
Quite honestly, if you're just driving around for fun save your money...
CA
dont go one-way front diff unless you're serious about racing. it's really not fun NOT HAVING BREAKS when bashing. trust me.
another added benefit of running a front one-way diff is that it allows a much more aggressive turn-in, as you dont have a diff up front regulating how much power goes to either wheel.
