having problems with ntc3
i stripped the spur gear and replaced it. when i turned my car on today it stripped again the clutch is spinning but the spur gear wasnt contacting i guess. i dont know what the problem is. everything is in place and stuff and it was a brand new gear. help me, i dont wanna go thru more gears
RE: having problems with ntc3
Copied and pasted my post from the other thread.
You need to check the gear mesh. Next time you refit the engine, fold a piece of photocopy paper in half, push the pinion (clutch bell gear) against the spur as hard as you can. Do up one of the screws. Now insert your folded paper into the gear mesh and rotate the pinion, feeding the paper in. It should go in with some resistance, if you can't get it in at all, mesh is too tight, if it goes in easily, mesh is still too loose.
ok so right now since everything is on and in place the paper should go in with some resistance. its 1st gear that keeps strip[ping on me. right now im thinking maybe it too loose because of the way it stripped like it was barely tuoching the pinion gear. how would i adjust it?
ok i did it. i did ajustments and stuff, is it good when the paper takes the groves of the gears. i dont want to start it just yet because im scared the gear is gonna shred again and that was the last one at the hobby shop until the next order.
NY
Yeah the paper is supposed to go in between the teeth of the gears, that way when you slide the engine back in you'll have the proper gear mesh
