RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
18ss engine issues!
Old 05-05-2007 | 08:47 PM
Default 18ss engine issues!
i started running my rs4 3 18ss today for the first time. when running for a good 5 minutes not using full throttle the engine shut off and ever since ive had a hard time starting it back up! there was also alot of oil that was seaping from the engine abit and i dont know if thats the cause of the problem. I tried taking out the glow plug to see if the engine was flooded and some oil was coming out from the side of the engine where the exhaust pipe gets connected to. its turned on but would then die out on me again. any help would be appreciated!
Old 05-05-2007 | 09:29 PM
hpi apollo's Avatar
Default RE: 18ss engine issues!
its all in the tuning young grasshopper
http://www.rcuniverse.com/forum/m_5517128/tm.htm
read it all, then read it once more, then read this
http://forums.radiocontrolzone.com/s...&highlight=FAQ
Old 05-05-2007 | 10:09 PM
nitroveins48's Avatar
ORIGINAL: speedbreaker
sounds like you are running way too rich! what temps are you running?
Old 05-05-2007 | 11:40 PM
im not sure what my temps are ima noob at this!
Old 05-06-2007 | 12:34 AM
i think it might be an issue with my engine being to oily, theres quite abit of oil around the sides of the engine and prob inside it has anyone experienced this? can anyone give me any good tips as far as cleaning out that excess oil!
Old 05-06-2007 | 09:03 AM
GYNAIKAS's Avatar
Leaning it out a bit could be a good idea but I don't think that's the problem. It might also be too lean and engine dies at high temps lacking of compression. If everything is ok (car doesnt spit out unburn oil from the exaust and also always blue smoke comes out of it) then your problem might be the low speed needle. Too rich low speed needle setting can cause stall when Idling for a long time and also too lean can cause overheating.
Old 05-06-2007 | 12:07 PM
hpi apollo's Avatar
dude, read that guide, it will cover almost every question you have, please read it, i wrote it to help noobs like you
Old 05-06-2007 | 12:24 PM
GYNAIKAS's Avatar
Despite of the fact that I've never read apollo's guide, I'm sure that everything he wrote is 100% helpful to everyone. Trust us and you'll never regret it.
Old 05-06-2007 | 03:32 PM
hpi apollo's Avatar
my guide compltely covers tuning and the temp thing too, gynakis...i found that rather amusing
