RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Engine help needed!!!
Old 06-13-2007 | 10:53 AM
From: Hamnish, LeominsterHerefordshire, UNITED KINGDOM
Default Engine help needed!!!
my ts4n seemed to be to lean and has splutterd petrol due to much going to wherever and its left a rustyt mark on the cylinder and mainfold can i get this off and any suggestions??
and ps buggy question what fuel for hyper7 16 ok??
i know not to do with on road but hey!!
plzz get back to me!!
cheers
Old 06-13-2007 | 10:56 AM
Foxy's Avatar
Default RE: Engine help needed!!!
I'm not clear on the problem with the TS4n, can you explain a bit more?
Fuel for the Hyper, 25% if you can get hold of it, 20% if not. It will run with 16, but not as well as it will with 20+. You may even need a different glow plug to get it to run with 16%.
Old 06-13-2007 | 11:17 AM
thanks well the engine was to lean and led to fuel leaking and leaving a rusting mark on the cylinder and metal parts.etc
and flooded easily due to the amount of fuel being pumped through
can i get these rusting marks off?
and are the wheels meant to be loosish?? because since i crashed it flat out i cant remember + the wheels dont run straight!!
help [&o] hehe
wb
Old 06-13-2007 | 11:30 AM
Foxy's Avatar
I think you might mean the engine was too rich, unless I'm still misunderstanding...where is the fuel pissing out from exactly? There's nothing you can do if your internals of your engine are scarred, except replce the damaged parts. I would suggest to just get another cheap .12 engine and tune it a bit more carefully this time.
As for your wheels, no they shouldn't wobble too much, check the rods and ball ends in the steering system for bends or looseness, and replace whatever is necessary. Have an experienced person check the car over for you, as it doesn't sound like you have the expertise to successfully diagnose all the potential problems you may have. Of course I mean no offense by this, I had a ts4n for my first nitro car and I also destroyed my engine and crashed it plenty.
Old 06-16-2007 | 01:02 PM
yh i totaly agree its all about understanding and experience
but I am learning getting to grips with ma m8s hyper.28
and im getting a hb lightning pro
wb
