new pullstart 18 tz ??????
WI
has any1 tried breakn in the new 18 tz tx yet , u know , the pull start version ? i tried to start mine tonight , first tank , the pinch is so tight it getts stuck top dead center every 2 pulls .....i gotta blister started now . i really dont like bump boxes , to much more stuff to haul around , but can u start a pull start motor , with a bump box , with the pull start still on it ??
RE: new pullstart 18 tz ??????
Yes you can use a starter box for that pull start motor but you could have also used a heat gun to warm the block up a little to loosen the pinch some.
