Rapid VH A6 - World Racing shift adjustment
Hey there, i bought this car, and the 2nd speed is being shifted very soon, with very low RPM and i would like to change this to shift only with 1st speed reaches a medium/high RPM.
The main problem of this car is the user manual, that is very poor and doesn't cover this kind of information.
does anyone knows how can i do that ?
Best regards,
Best regards,
RE: Rapid VH A6 - World Racing shift adjustment
Disaseble the transmission gears and search for a small (usually "Allen" type) screw on the "one way" gear. Turning it clockwise -> shifts later, turning anticlockwise -> sifts earlier.
I'll try to find this, but what i saw 2 screws in this place (2 holes)
1 straight and another inclined.
Witch one i unscrew to shift later ?
Thanks for your answer !
the straight is to hold the gear tight to the axel. The inclined is the one you should adjust. Give it 1 1/2 turn clockwise for start and see if it needs more latency.
Now it's ok, i'm shifting when the car reaches the RPM of almost 3/4 of throtle.
I think this is the best setup to me.
Thank you again !
Thank you again !
