Problem in my inferno!!!!!??
HI
I'm new in nitero car i bought kyosho inferno mp7.5 before 2week
but i have problem the car turn off after 10m and some time immediately and i think it's from the idle mixture and the needle valve,
but some people told me may it from the clutch
so plz any one can help me.
and sorry if there are wrong in my English coz im from Sultanate Of Oman.
RE: Problem in my inferno!!!!!??
Maybe you need to change glow plug. Or the fuel mixture setup is either too lean or too rich. Try to bring the needles to default position get a new glow plug and then set your engine working properly. If problem continues try checking for small dust in your fuel line or carburator. I hope my info helps......if not we'll figure out something else!
Alshokaili...ur my neighbour! I'm in dubai...
screw in the high speed needle to the end (not too tight!) and then unscrew it 2 3/4 turns (yani 2.75 turns).
turn the engine on and give it just a little throttle...if it turns off then tighten the high-end needle a little more (not more than 1/4) and turn the engine on and give it a little throttle again and see if the engine turns off or no. If it still turns off then tighten again 1/4 turn (now we are at 2.25 turns out), and try again to get the car moving. If this doesn't work then we have to look at other things. Follow the checks Gynaikas told you to do.
tell me if this works.
salam
salam
HI
rockinro
I change the glow plug and i play with needle and now it's work for 15m
after that turn off is that normal coz of heat
and one thing i want to know what u mean by speed needle it's the needle valve or something else.
salam
rockinro
salam
well its always hard to help without really seing the problem... but i would say you are running the car to rich => engine gets to hot and turns off
if you dont have a tempsensor try this... imidiatly fullthrottle and if the engine turns off or stutters its way to rich(ofcause after warmup)
NOOOO!!!! Overheating comes from too LEAN engine not too rich!!! Too rich engines are not capable of max rpms and don't overheat!
THANX FOR every one
I'll try after tomorrow coz i have exams this days
and i'll told u what happen ok
one thing 2day when i want start my car i fell the recoil it come free some time??????
see u guys.
see u guys.
try the full throttle...if it dies immediately then it is too rich...if the engine rpm goes up and down n is not consistent then it is too lean.
the high speed needle is the main needle...the large one sticking out of the carbureator.
also as DIABLOTAC said, if it turns off when u brake then check the idle screw (the very small screw that has a spring on it)
If u are able to run it for 15 minutes and then it dies, then i think it is too lean and is overheating.
tell us what happens...check also with your hobby store because they will be able to make it run correctly.
