Is this a straight swap into an RS4 3? O.S.18CV-RX
This one here...
http://www2.towerhobbies.com/cgi-bin...4&I=LXGGP7&P=K
Will this swap straight in or do I need to buy other stuff?
Thanks all.
Thanks all.
RE: Is this a straight swap into an RS4 3? O.S.18CV-RX
I dont think there will be any problems because it's an .18 engine and as I can tell from the picture the mounting positions are suitable....it would be better though if someone who has already installed that engine on his RS4 could tell us...just to be sure.
u might need these motor mounts....
http://www2.towerhobbies.com/cgi-bin...?&I=LXN373&P=M
unless ur car already has them..........everything else is direct drop in!!!
Thanks guys.
Will my old clutch,flywheel and gears go straight on as well? Also will the standard pipe and manifold go onto it? Can't affor tuned goodies just yet.
Thanks again!
Thanks again!
ORIGINAL: GYNAIKAS
What are exactly your old clutch,flywheel and gears? From what car/company?
The standard stuff from HPI...It's the Evo so it's a .15..
NY
it fits right in, the TZ doesnt really however. The clutch should be fine, but u need to buy a clutch nut to put the clutch on the short shaft. U should def. get it, i hear its a great engine.
well ill tell you a darn good thing about those engines. i have one in a street force and its crazy. i cant keep it straight and it eats tires like crazy.
.18 Tz is the most powerful engine you could possibly get for the RS4 without having to modify it (except from the rear exaust system).
NY
ORIGINAL: Krashu
Would I get that nut in tower?
Thanks again!
Thanks again!
NY
the TZ is freakin hard to turn over, without the glowplug, the pullstart is just as hard as my other engines with it in! the CV-R is alot more user friendly, and easier to use.
Omg dude remove the rubber tube you've atatched to the pipe it's a crime with such an engine!!! Every single cm of it kills torgue at high rpm!
Just ordered:
-Associated Clutch Nut NTC3
-HPI Aluminum Engine Mount
-O.S. 18CV-RX w/11J Rotary Carb
-HPI Rear Shock Tower Graphite Nitro Rush
-HPI Turnbuckle 4-40x34mm
-HPI Flat Head Screw 3x18 RS4 Pro E-Savage (10)
-HPI Sway Bar Set RS4 (6)
-Traxxas Header Screws (6)
-HPI 1/10 Molded Wing Set Black (2)
-Ofna Engine Tuning Screwdriver (3)
-HPI Wheel Nut M4 Purple (5)
210 bucks. I feel lighter haha. Should make my RS4 a bit better.
Again,thanks everyone who helped me!
There's no front one of the site..
It'll do until I can afford to go fully graphite.
