whats wrong with my car?
HPI RS4 3 SS
engine running- the car has a hard time moving forward
engine off- the car rolls forward but locks when you try to move it back
the clutch is good, but it only happens with motor in and gears meshed
thanks
thanks
RE: whats wrong with my car?
Maybe the one-way ball-bearing of the bigger plastic transmission gear is installed on the wrong direction. If not then maybe some teeth of the gears are damaged or the brake applies at idle.
