what to use to drill body holes?
RE: what to use to drill body holes?
I dont know the name of the tool in english but at its end it has 3 razors ending to a common sharp edge. Otherwise you can use a common drill using 5-6mm diameter but with extreme caution.
for what i used for my truck yes its a hole saw....its a drill bit witha circle shaped saw on the end. it cuts a perfect hole everytime
CA
"REAMER"
It's a conical-shaped blade in the form of a hand tool so you can control the size as you rotate clockwise into the lexan.
ORIGINAL: Scavolini
"REAMER"
"REAMER"
ORIGINAL: silverj
Or this Hobbico Circle Cutter from Tower Hobbies!
I use one of those as well. Excellent product,great for wheel arches too.
