Would like any help possible
FL
I hjave an old HPI Nitro RS4 3 RTR (from like, 2002ish maybe?)
It's been working good and all, but recently my radio started going mad. As soon as I turn on the engine, the throttle goes insane and just goes WOT and glitches like crazy. It doesn't happen while just the RX and TX are on though, only once I power up the engine. I've taken out the RX, cleaned it, made sure everything was plugged, but can't find the issue. Any ideas?
Thanks in advance!
This started happening about a month or 2 back, and I got fed up and decided to switch to electric. I'd still like to be able to run my nitro though. Thanks again!
Thanks in advance!
RE: Would like any help possible
First off, you made the wrong move by going electric[:-],second,electrics can have the same problem.third,check your radio wires to make sure they are not frayed as nitro will cause vibrations,mkae sure the wires are not laying on metal and that your receiver is not laying on metal,next xhexk your crystals and make sure they work and finally check your batteries to make sure they are charged right.
FL
I know it can happen with electric too, but electric is just easier in the long run and I don't have the time to keep maintaining nitro and tuning and stuff, and electric is cheaper
All the wires are fine, no frays, not touching metal, and the RX is in a good place. I guess the only thing to check is the xtals, I'll check on that tomorrow, thanks a lot!
ive heard something about metal to metal interference or sumtin along those lines..maybe one of the other guys cud tell u about it but that may be ur problem..
FL
It seems I've eleminated any other problems but the xtals, I'm gonna pick up a new set on my way home and see if that solves it. Thanks, I'll update once I've tried it
ORIGINAL: x2o
Thanks in advance!
Thanks in advance!
FL
Well, I checked today and the crystals were fine. I think it may be the throttle Servo, I noticed today that when you turn it on, it snaps into the right position, but if you try gassing it it moves like 2 cm and then won't travel any further. Might try buying a new servo, actually i have a futaba S3003 servo laying around, i think there the same size. Might give it a go next time i get a chance
I had the same problem with my old Hitec Ranger II. No it's not the servo's fault it's the receiver's contacts. Try clearing them and install a new servo to see what's gonna happen. If problem remains then your receiver is vulnerable to white noice that comes from the engine's vibration.
