Car Wont Shift
Car Wont Shift
I have any Exceed RC. My car was running perfect until one day it wouldnt shift to 2nd gear. We took the transmission apart and the teeth in the gears were worn so I replaced them and spaced them perfectly with the engine. My car still wont shift into 2nd now. We adjusted the clutch throwout but still doesnt shift. Any body got any ideas??
RE: Car Wont Shift
Maybe the 2nd gear's "clutch" shoe is worn off and it is not capable of transfering the power through the 2nd gear any more...in simple words: No shifting.
RE: Car Wont Shift
sometimes we look in the wrong place two fix the problem. did you change the carb setting cause somtimes if its not tuned well it wont change to second gear . clutch engage in a certain rpm if you cant tune it go to your lhs.
RE: Car Wont Shift
ORIGINAL: GYNAIKAS
"DIABLOTAC78 " is right, that may be the cause of your problem too. That's why I wrote "maybe"
