Upgrade engine, upgrade clutch? Tuning clutch?
From reading around, it seems it's fairly common for people who upgrade engines to upgrade the clutch system at the same time
I didn't do that when I put a 15CVR intoy car and it seems to run fine
Is this an issue?
Also, I was thinking is it possible to put a higher tension spring so the clutch engages at a higher rpm for a better launch or is this going to be bad for driving?
Is this an issue?
NY
RE: Upgrade engine, upgrade clutch? Tuning clutch?
that is not an issue at all, but its just preference, some guys dont like having an old clutch on a new engine, since theres a bunch of better ones out there. you can put a harder spring, but itll just need a higher rev to get going, but the punch is excellent
I could imagine getting off the line would be much better
What happens if my clutch spring is more like a rubber band than a spring?
eh,
Well no on my car the clutch is 2 shoe and is held by a thick rubber band type thing instead of a spring around it
Never heard of that before. Surely as the engine heats up the rubber would become softer so it would engage too soon... But you would only really need to uprate the clutch either if it was slipping from too much power or personal preferance...
Aluminum clutch shoes? I'd never buy ANY aluminum upgrade for my car...get triple racing clutch shoes with the proper lightweight flywheel...that would be my choice!
NY
wait, so u would rather have plastic clutch shoes that can melt at high usage? racing clutch shoes are aluminum btw, not plastic. I have the lightweight flywheel, and i cant tell the difference, ut it looks good! lol
Well racing clutch shoes are not plastic they are made from ritine and they are supposed to wear off (very slowly) in order to achieve maximum traction between the shoes and the bell. Aluminum ones will never wear off, i agree, but ritine shoes are used even at centax type clutches (My sirio on my ex RRR had). Since I havent tried the aluminum ones I can't say if they're good or bad and I trust your opinion.
NY
yeah, i used my plastic stock ones for a bit in my buggy, and it melted slightly, and didnt engage over 1/4 throttle. u dont notice the difference between the shoes, until they go, lol
CA
ORIGINAL: Spetz
Is this an issue?
Is this an issue?
Here's a few clutch upgrade ideas:
2 shoe to 3 shoe: gives greater "bite", so the clutch will stay engaged under heavy loads, and grab hard when it engages
stiffer springs: increases the RPM at which it will engage. Good for harder launches, and smaller engines with high RPM peak power
lighter bell: spools up quicker, and slightly increases max RPM
lighter flywheel: spools up quicker, but launches softer
push-type clutch: offers full adjustability, and excellent "bite". downside is that it is physically longer and requires new motor mounts, and may not fit in all cars
alum & composite shoes: most ars come with plastic. These offer better "bite" and longer life. Composite will not leave deposits on your bell, and will not change coefficient of friction with high temperatures
CA
ORIGINAL: ferrarimk13
very good suprachrgd82. To lighten up a clutch bell, can you drill holes through it?
It may throw the balance way off and give you unwanted vibration. Chech with MIP first, but you absolutely must, drill holes ONLY if you can statically, and dynamically balance it when you are finished.
If you attempt to drill holes they wont be exactly symetric even if you are as precise as any human can't be,so chasis will suffer from heavy vibrations at high rpm.
