rally conversion
ID
rally conversion
I have a ntc3 and I have found places that say the rally conversion will work on this car and other places say that it is only for the electric tc3. Does anyone know if if will work on a nitro car, It would be good to know before I spend the 65$, Thanks in advance for your help!
RE: rally conversion
Are you gonna race off road with that car of it's just for fun? And what exactly is the surface you'll be running on? If the conversion kit's parts fit your car then there's no problem! The purpose of the conversion is to gain some height from the ground to obtain the desired ground clearance. Ask your distributor if they've ever tried it on a nitro NTC3. I dont think there will be any problem but I'm not sure about my claim and I can't carry the burden of such a choice....wait for more answers.
ID
It will be just for fun, I plan on using it in fairly mild off-road areas. I was almost debating on whether or not I would need it since you can get lots of clearance out of a ntc3 to begin with. However the little extra would be fun!
GA
i cant help much but i know you can do it with a RS4, just get the rally tires and jack up the tc3 as hige as you can, the tranny may not like it to much though
