Help with diff
IN
Help with diff
Im the same one that needed help with the handeling of my 4-tec. A lot of you suggested oil filling the diffs. One person said to oil fill the inner casing and not the one with the gear that bolts to the chassis. I took the front diff out and there is only one caseing. It has the teeth of the gear on the outside and four screws holding the side plate on. That comes off and it has the gears on the inside. I only have the stock diffs, not the ball diffs. Can this diff still be filled with oil without it coming out?
