wider tires on rear "NTC3" lookinf for a pic
NY
Looking for a picture, if someone has one, i assume it can be done with offset wheels like serpents and such.
RE: wider tires on rear "NTC3" lookinf for a pic
I think I've seen one...I'm not sure if it wan an NTC3...check ntc3 official thread if it's not there then where else????
I put some Calandra Racing Concepts 35mm wide rear tires on my TC-3 here is the only picture I have . Tires did help improve handling I had a Sirio .18 in it.
NY
nitrohead 5300
THANKS, exactly what i was looking for, I figured that would improve handling plus it looks a bit meaner.
They should fit without any major mods beyond shimming. Here is their website http://www.teamcrc.com
My Feedback: (8)
The shims I think he's talking about are little hex shaped spacer washers that go between the hex and the wheel to space the wheel out a little further.
The CRC wheels I bought came with 2mm thick shims/spacers.
The only issue you might encounter after using them is that the wheel stud is not long enough for the nut to fully thread on and lock?
ORIGINAL: nitrohead5300
ORIGINAL: proptop
RS4 also has a problem with anything ore than 30mm wide rear...it can't fit cause it's the radio tray near of it. 30mm is the widest I could fit without touching the tray...
ORIGINAL: proptop
Actually, I bought them to try on my Fusion...but they still rubbed on the toe link ball cup, and the nut would barely thread on.
