Carb inserts
VA
RE: Carb inserts
ORIGINAL: evil
Id say he is talking about a carby reducer[8D][8D]
RE: Carb inserts
Personally i would tell you not to bother trying to find carb. inserts,instead either dial out some of the throttle travel on your handset or if you do not have that option then you can move the position of the throttle link on the servo horn to ensure you cannot reach full throttle.
RE: Carb inserts
ORIGINAL: Pillbots
He means venturi inserts.
ORIGINAL: GYNAIKAS
I haven't heared of it before...but why make it slower? Just curious...
RE: Carb inserts
Yes it's ok but the venturi effect is used where you want to change the air-flow of one surface...what does it have to do with the carb? The air filter goes on top so there's no venturi effect... Any pics?
RE: Carb inserts
Here you are....the Nova has different sized inserts for the carb. inlet,this will restrict airflow.Three different sizes;9,8.5 and 8mm
NY
RE: Carb inserts
yup, a lot of stadium truck guys use em right? to choke the power a little? I think you should listen to Anthoop and just dial down the EPA's so it doesnt open completely.
VA
RE: Carb inserts
I can't turn down the epa's because I still have the radio that came with the car. It's the original rs4 3 rtr. How would I adjust the linkage so it doesn't open all the way?
GA
RE: Carb inserts
The Sportwerks .26 comes with them too.
There are several things you can do to reduce the servo throw. Change the position of the servo horn, change the length of the throttle linkage, sometimes you can even loosen and rotate the carb. Does your radio trim controls? If so you can use the linkage setting combined with the trim can be a crude kind of end point adjustment.
RE: Carb inserts
ORIGINAL: manndexter
RE: Carb inserts
ORIGINAL: Anthoop
Lol....that is NOT a word!!!!!
ORIGINAL: GYNAIKAS
Ahh...now I see we call it "pnihtis" in greek!!! LOL
