which way do i turn the idle screw
1 Post
RE: which way do i turn the idle screw
ORIGINAL: TOMLANE
which way do i turn the idle screw so it will idle on my acme cyclone?
A good starting point is wherever the manual says to set it. With the weather where I am in Aus (average of 20+ degrees celcius), the factory settings are always too rich. Not sure about where you are though. Either way, if it's too rich (if it runs for a while and slowly loads up and dies), turn it clockwise 1/8th of a turn at a time and keep trying.
Did this thing come with an engine manual at all? If so, you really should spend the time reading it. If not, you should see if you can download one.
1 Post
I've just been trying to find some info/specs on this 'Acme Cyclone' that you've got, but I'm coming up short on engine details. Does yours have the Team Infinity 15S engine? If so, I'm not sure it even *has* an idle mixture screw. From the photos, it looks like it's just got a throttle stop screw. If that's the case, just turn the throttle stop screw in far enough so your engine stays running.
