rs4 3 evo+ drift setup any help?
I want to buy the stage d conversion but i hear that doesnt really matter if you actuall do the right mods to your car. Ive tried the electrical tape around the tires, yeah that doesnt work at all. Im wondering if anyone knows how to set it up to drift. Does drift tires really make that big of a difference.
IL
RE: rs4 3 evo+ drift setup any help?
buy some HPI drift tires, stiffen up the suspension a little, make extra cooling holes in the body (side window's) to keep the nitro engine cool while reving, and going sideway's.
i used to have a front 1 way diff....you might want to try one of those out.
i was pretty big into nitro drifting years ago, and im just now getting back into it.
i will be buying a RS4 3 evo+ to drift/bash with.
its all in the tires, suspension, and learning throttle/steering control....get some tires, tweak the suspension...start drifting...make changes to suit your need's.
IL
forgot to add:
adjust the camber if necessary also...adjusting the front and rear camber will take away traction from harder compound tires on an awd car.
the stage d kit uses a single speed tran's....you could try messing with gearing or just locking out your 2nd gear for drifting.
iirc...i used to have a problem with losing control when rpm climbed and 2nd gear engaged.
FL
ORIGINAL: Cypriot Boy
well a suggestion would be to have no fluids on the front diff and lock the rear....
just to warn you dont use wot 3/4 trottle the most \, because you can over rev your motor, and keep a good eye on your engine temp.
happy drifting
Also it helped mine to cut out a hollow spot in the foam bumper and stuck in a big hunk of lead. Sounds wierd, I know, but it really helped maintain control without spinning out. The tape worked great for me, did you put it on all 4 tires? It let me still have decent speed going straight, but then turning and hammer the power and it will drift great at high speeds as well as slow. Wish I could tell you how much weight I put in the front, had to be at least 4=6 ounces at least though. Good luck with your project!
you need the drift tires because regualar tires have to much grip and they would be hard to get to drift with because the engine will have to rev higher than nessicary.
precisely
but i suggest that you get the falken drift edition from HPI
considering your runnign an evo+ they have more power
and the falkens give oyu better drift control at high speeds
