Ofna GTP
RE: Ofna GTP
Hi. I use 50k diff oil front and 10k rear. Stock shock oil for now. One upgrade to be sure to get is hardened steel bevel gear for diff, stock one goes out fast. I use front spacers in stock location on upper arm. Rear spacers(for wheel base)I put them all in front of axle carrier to make wheel base longer. I use foam tires and set camber for even tire where, then switch to treaded rubber tires. It is a very fun car to play with, but really doesn't handle all that great because of it's weight and ultra mushy suspension. Not saying it handles bad by anymeans, just not as good as I had hoped. I can't remember offhand where my rear camber links are set. Rear shocks are in outer hole on arm, and middle hole on shock tower. Front shocks are inner hole on arms, and upper hole on tower. Toe is about 1.5 degrees out in front, and in back the cams are set for max toe, can't remember if it's 2 degrees or what? Thats about it for now, main thing is to get used to driving it and have fun. I love this car as it is so easy to "save" when it gets out of shape like going to fast into a corner. It's very hard to really lose control(except for radio failures)when driving it, only thing I don't like is the way it goes through tires[:@]. Let us know how it goes for you!
