Nitrostein with clothes on.
RE: Nitrostein with clothes on.
ORIGINAL: Brent Davis
Looking good man. Is that the NTC3 car under it?
ORIGINAL: trini4life
niceee. did you do the skull yourself?
Hello Ziggy , how are you doing?? Busy I bet!! I am having so much fun running road courses with this car when I get tired of doing that I may gear it up and do some speed runs.
I am going to put a highly modified OS TZ.18 in it use the 220mm conversion kit tires and really smoke my buds roadracing because the center of gravity and balance of the car will be alot better than if I put a .21 in it. Here is a picture
Nitrohead, youre instaling a highly modded tz, who modded it? You, AB, or EB?
I have the same engine and tried the same exhaust pipe, and it was no good, you loose too much at the top end. So if you havent tried it, you may be unsatisfied
ORIGINAL: Car-Boy
Yes its the hole, you loose too much presure for top end. but at take off its pretty good, but just the take off.At the top end you just loose alot.
only if the hole was smaller it would be great
Thanks for the info when I am testing it and if it appears to be losing power on the topend I will just put a smaller piece of brass tubing inside the stinger.
I have the EB Mods OS 18 in my RRR with a 220mm conversion. The engine does not rev like the .12s but has double the torque. The only problem you have is gearing. You need to geear it up as high as possible. You can get a 19t first gear and a 24t 2nd if you look hard enough and thats plenty for the car.
I run mine as a street racer and it flys
Cheers
Cheers
