RCU Forums
-   RC On Road Nitro Cars (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/)
-   -   problem (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/2734085-problem.html)
rasta 03-06-2005 06:11 PM
problem
my new yokomo car I got about 3 weeks ago has been acting kind of weird, it will not turn on without me pressing the throttle a bit, and when I do get it running it will shut off in about 7 seconds, my dad said he has been messing with the idle screw and trying to get it to work, so yeah that might be the problem, and if it is how do i get it back to normal, thanks, bryan.
BOWTIE1 03-06-2005 06:57 PM
RE: problem
ok will the car set still and idle ? if not u need to run the idle secew in some till it will , after u do that u shuld be ok if now try resetting the servo and that should get it going
redrider98 03-06-2005 07:06 PM
RE: problem
try turning up the idle.
rasta 03-06-2005 08:32 PM
RE: problem
Still won't work Ive tried to run in the idle screw and nothing it won't stay on for longer than 7 seconds.
Somers Racing 03-06-2005 09:31 PM
RE: problem
Lean out the low speed needle. It is to rich and is flamming out.
Pete
P.S. Only lean it 1/16 of a turn or 1/8th of a turn.
BOWTIE1 03-06-2005 10:09 PM
RE: problem
rasta ,
if u still have the paper work for your car i would put the settings back to the orgnal settings ,
just a off guess how much compretion do the motor still have ? is the flywheel easy to spin over?
