RCU Forums
-   RC On Road Nitro Cars (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/)
-   -   HELP serious Problem!!! (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/5000424-help-serious-problem.html)
nitrorczzz 11-15-2006 05:09 PM
there is alot of radio interferance when ever the engine on my nitro car is started. the throttle and brake servo goes crazy!!!
i cant even use it because it revvs up and i cant controll the brake i can only make it go faster.
it came with cheap servos and i got new ofna ones with a ofna receiver and radio.
please help me out with any ideas you have please please please...
hpi apollo 11-15-2006 07:42 PM
RE: HELP serious Problem!!!
make sure everything on your car is on tight, loose metal parts vibrating can do this, also, how close is the antenna to the engine, and get a radio failsafe
nitrorczzz 11-16-2006 12:12 AM
well the antenna is literally an inch away from the engine but my other rc car was like that too and it worked fine the only difference is the upper support peice thing was plastic and there was a plastic housing box for the radio and batteries.
the only shaking metal peice is the brake controll thing that connects to the servo arm and through the loop to pull on the brake pads...
Ybenjulkay2x 11-18-2006 08:42 PM
Have you tried diff. Servo might have bad servo.
nitrorczzz 11-18-2006 10:53 PM
i actually tried a whole new radio system from ofna and still the same thing but a little better
ORIGINAL: Ybenjulkay2x
thedub88 11-19-2006 09:17 AM
go somewere else like across town or the next town over. It could be that the guy across the street is secretly sending radio transmitions back to his home planet. LOL
Could be interferance from something near by
nitrorczzz 11-19-2006 01:09 PM
so what about a noise absorbing... thing. i heard about it somewhere.
hpi apollo 11-19-2006 01:57 PM
if you live near large powerlines it can cause interference, just run a failsafe and you should be fine
nitrorczzz 11-20-2006 03:34 PM
i would run a failsafe but the problem is that it almost is never controllable its constantly spazzin
previ 11-20-2006 04:49 PM
You have to start by a process of elimination.
Before starting up your motor switch on the receiver ONLY and see whether you get any glitching.
That will eliminate any local interference that might be causing the problem.
If that is fine then get the transmitter ON and the receiver ON as well. Any probs there?
If you ONLY get glitching when the engine is running then its a matter of poor screening from the high frequencies caused by the moving mechanical parts, and that is usually the receiver and antenna. Make sure that the receiver is well fixed with double sided tape and does not vibrate when the engine is running. Check also the crystal, remove it and make sure the sockets are clean.
You should also make sure that the antenna is not cut or being trapped under anything. Avoid coiling extra length from the antenna.
Hope this helps...!!
nitrorczzz 11-20-2006 06:14 PM
well ill try it tomorrow. thanks. it only glitches when the engine is on, its completely fine with the engine off.
Timmahh 11-20-2006 07:27 PM
make sure all your metal to metal parts are tight, also check for a different route for the antenna wire if its near the engine.
Timmahh
nitrorczzz 11-20-2006 08:09 PM
thanks will try tomorrow too.
