My 2.2" Crawler Project with Pics.... (Phase 2) *PICS*
CA
Here is phase 2 of my 2.2 crawler with it's new chassis, steering setup, rear motor skid (I need to protect my $50 :shock: aluminum motor mount) esc/receiver mount. I am just waiting till Monday to stop by Novak in OC and rplace my Rooster esc.
Next week I will be cleaning up the chassis a bit, like rounding the corners, drilling a few holes and the same for the esc/receiver mount.
HOP-UP List -
Here is my 2.2 crawler that started out as a Tamiya Hummer. It now has the following -
Cut HPI MX-1 Body Painted Red
Wild Dagger Suspension (Wider than stock)
Stainless Steel Hinge Pins
Tamiya Aluminum Hex Hubs
Red Steering knuckles
Hard Diff Cups
Longer TG10 Wheel Axles
Wild Dagger Dog Bones
Tamiya Lightweight King Pins
Wild Dagger Shocks (4" shocks included as well)
Full Teflon Bearings
RRP 16 Tooth Pinion
Kyosho Mega 360 Motor (Same as mag mayhem)
Tamiya Aluminum Motor Mount (Rare and Expensive)
Tamiya Heavy Duty Prop Shaft Conversion (Rare and Expensive)
Adjustable Camber Links
Both Diffs Locked
IMEX G-Hawg Tires
HPI Black Spoke Wheels
Novak Rooster ESC
Novak XXL AM Receiver
Futaba TX
2 Sets of Crystals
Hitec 645 MG servo
Kimbrough #124 Heavy Duty Servo Saver
Custom Aluminum Chassis
Associated Battery Cups
Aluminum Antenna Mount
[email protected]
HOP-UP List -
Hard Diff Cups
RRP 16 Tooth Pinion
Both Diffs Locked
IMEX G-Hawg Tires
Novak Rooster ESC
Futaba TX
2 Sets of Crystals
Hitec 645 MG servo
[email protected]
FL
RE: My 2.2" Crawler Project with Pics.... (Phase 2) *PICS*
Looks good I like the body,Whos it doa t crawlign dose it actually crawl or does it jsut run over the rocks?
Wow that looks really cool. Im intrested in building one exactly like that. Could you give me some more info on it? What kind of transmission is in it?
