RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
Making a Crawler
Old 07-06-2004 | 09:28 PM
Default Making a Crawler
Ok, So I have decided, I am going to build a Crawler, I totally stripped my rusty for parts and here's what I got from it:
1. The Diff and tranny, locked them already
2. Drivechain stuff
3. shocks and springs
4. shock towers (tossing)
5. hub carriers
6. **** body
Ok and here's what I plan to get
1. Custom Chassis, making my own
2. maxx shocks or 1/8 scale shocks
3. Body
Electronics
1. Novak T4 Hyperfet ESC
2. Novak XR2 Radio Gear
3. Power Maxx 2400 mAh NiCD batt packs
4. Deans plugs
5. Team Orion Pilot 27Tx1 Motor
Gearing
Spur: 87T
Pinion: 19T
Tires: Pede Tires (reversed for more traction)
LMK what you think and I will keep you posted on how it's coming. LMK what you think I should change
Old 07-07-2004 | 02:17 PM
Default RE: Making a Crawler
sounds pretty good man
Old 07-07-2004 | 04:04 PM
Bush Wacker's Avatar
Have you considered that 55turn motor, forgot what brand maby trinity.
Old 07-07-2004 | 05:29 PM
That would Be the Integy 55T Lathe Motor , yes but this is a BUDGET CRAWLER, notice by the custom made chassis and all. I would get one but I don't know where.
Old 07-07-2004 | 05:54 PM
Element's Avatar
integy sells them direct
Old 07-07-2004 | 06:57 PM
How much? and do I need a certain ESC to handle it?
Old 07-07-2004 | 09:49 PM
I dont think so, there like $27.
Old 07-07-2004 | 10:39 PM
ok thnx for the info, anything else I need to know, I am planning on using a gecko design for my custom chassis and some maxx shocks.... I will upgrade them later to piggybacks or aluminum. They need to be cheap, for now, and 4", what do you recommend?
Old 07-08-2004 | 07:17 AM
T-maxx shocks?
Old 07-08-2004 | 11:24 AM
the cheap plastic ones out of an rtr savage. ive seen 8 of them go for 8$ on ebay
wicked
Old 07-08-2004 | 07:02 PM
a 55 turn motor?[&:] wouldnt that be like 10 mph? or would it have lots and lots of torque
Old 07-08-2004 | 07:26 PM
Lots! of torque.
Old 07-08-2004 | 08:45 PM
fastfred's Avatar
Sounds like you've got a plan together.
Is that going to be 2 motors, front & rear? If so, the integy's are probably your most economical solution.
Remember that a stock motor has locked timing so you can't use those if you're going to run one in reverse. (I just learned this recently...)
Yes, higher turn motors are fine for a crawler. 10mph is more than fast enough. What matters most (engine-wise) is torque. I'm running 19 turn motors in mine, they have adjustable timing, and 9 tooth pinions.
m
Old 07-09-2004 | 01:12 AM
FastFred: No it is one going to be one motor w/ a diff and 2 maxx center diffs at the front and rear for drivechain. all 3 will be locked.... I am running the team Orion Pilot 27T motor w/ adjustable timing and a 19T pinion and 87T spur... I amplanning to switch to a lower tooth piniom, like between an 11 and 8T
Old 07-09-2004 | 11:53 AM
but a 2wd crawler? I didnt think 2wd crawlers make it very far? 4wd is the way to go.
Old 07-09-2004 | 01:31 PM
no, I am making my own custom chassis, I took the tranny from a rusty I had lying around and locked up the diff... I am going to mount to tranny to the center area of the chassis (the design is similar to the gecko 1 design) and then run my CV's down to front and rear where they will each be met by a T/E-maxx center diff (that will be locked) and then run 2 more CV's from those to the wheels. I'll post some pics when it's more in the process because It's just parts right now. I need to get some sheeting and stuff too, I have my list, just don't have time right now
Old 07-11-2004 | 02:08 PM
Ok I am going to go get some materials for the chassis today... what do you reccomend cutting the aluminum sheeting with... dremel too? with a cutting wheel?
Old 07-11-2004 | 03:03 PM
when me and my brother made his chassis, we used a jigsaw with a metal cutting blade for the majority of it, and a dremel for detail work.
Old 07-11-2004 | 03:15 PM
Yeah, at school to cut my chassis out i cut it out roughly on a band saw because the jig saw made it too 'jumpy', if you know what i mean. Then i just used some files and filed it down. I stuck a paper chassis template to the aluminium first though.
Old 07-11-2004 | 04:26 PM
how thick is the aluminum?depending on how thick i might also be better to use a blow torch to cut it out (roughly) and sand it done instead of burning your dremel up trying to cut through stuff too thick(i had to be very careful cutting that thick lexan jnot to burn up the dremel)
wicked
Old 07-11-2004 | 05:09 PM
Hey mtrchamp I'll race you to see who finishes their crawler first, I'm gunna get a tamiya twin detenator and biuld from there.
Old 07-11-2004 | 06:12 PM
ok but you have to fly to cali , good luck, I still need to get my center diffs, I JUST Started, I've been making my plans and my draft pics for like a month and a half
Old 07-12-2004 | 08:02 AM
Whoever post's finished pics firts wins.
Old 07-12-2004 | 04:04 PM
ok, I going to get pats today...I said yesterday but I didn't, I may just build the chassis out of 3/8" lexan because it's stronger then just an aluminum chassis.... lexan and maybe some 1 or 2 mm sheeting to sandwich in behind it....
Old 07-13-2004 | 12:38 AM
ok, first stage of many is complete, tonight I mounted the tranny, and cut out the underchassis, the underchassis is made of plexiglass and is a lot more stronger then the 23 GA steel sheeting I got.... I dunno if you can see from the pics but there is a peice on the bottom... sorry for the grainy pics, I will keep you posted.... I also made the front and rear cants.... no pics as of now though...
ID:	153126   Click image for larger version
