Crawler radio question...
I am just getting organized to build my first (budget) crawler. I have a question regarding electronics. I am starting with Clodbuster running gear, and I have a Novak Super Rooster speed control. My question is which type of radio is best to use - I want front/rear steering independent of each other, so I want to use a 4 channel radio. Which radios are compatible w/ a the Novak sc?? I am considering an older Futaba 4 channel, but should it be AM or FM.
Thanks in advance for your help!!
RE: Crawler radio question...
Well is there a radio that is a pistol grip style that has a 3 ch setup that can say steer the front with the wheel and maybe a lever for the rear?
there is radios like the tmaxx which are 3ch but for the 3rd channel ir is all left or all right, cause they are used to shift and stuff
