Rod ends
FL
Rod ends
I'm starting a TwinForce crawler. Four linking it. What rodend to use on this size of truck? I've got 1/4" rod to use for the links but I think the 4-40 rodends will be to small. What would YOU guys use for the links and rodends ? Thanks.
RE: Rod ends
well I am kinda new to this but found that the Losi Larger ends were Much nicer then the Traxxas or the ones that "Others" sell. They are a 4-40 ball hole, and 8-32 stud. They alse were only like 10$ for 8 with very nice balls that have a cup built in to them for the hardware to be hiddin inside..
FL
RE: Rod ends
What is the OUTSIDE dia of the thread'd part of a 4-40 dubro rod end,,, and the same for the Losi 8-32 rod end ? Like I said I have some 1/4" OD aluminum rod.
FL
RE: Rod ends
Come on guys... I need to know which rod end will match a 1/4" rod well. Or what size rod and rod ends to make links for a Twin Force truck?
