RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
stampede crawler
Old 01-11-2007, 08:02 PM
Tyeide
Default stampede crawler
hi i have a xl-5 stampede I was wondering if there are any mods that will make it crawl good. I was also wondering how well it would do.
Old 01-11-2007, 09:38 PM
Kody P
Default RE: stampede crawler
if you rebuilt the truck and made it have four wheel drive it might work better than stock anyways
Old 01-11-2007, 10:27 PM
dezfan
dezfan's Avatar
Buy a TLT.
Old 01-12-2007, 12:06 AM
hands without shadows
hands without shadows's Avatar
http://www.rcuniverse.com/forum/m_5042061/tm.htm
Old 01-12-2007, 01:26 PM
Rare
Rare's Avatar
ORIGINAL: dezfan
Buy a TLT.
WoW![X(] That sure clears things up for him.
Old 01-12-2007, 08:25 PM
rcbif
Independant and 2wd truck dont make good crawlers. Sure you could put a rear end on the front and make it 4wd but it depends how much you want to put into it, and it would still be independant suspension. You could go for more of a hill climber
Old 01-21-2007, 01:52 AM
lohocla
ORIGINAL: dezfan
Buy a TLT.
he asked for mods for his pede. .. maybe he doesnt want a tlt.
Old 01-22-2007, 11:03 PM
rustlerbasher
a stampede will get "stuck on a bannana peel" when compared to 4x4 trucks. Your kinda starting your self off for failure... crawling is all about traction and forward bite... without 4WD you have no forward bite in the front..and it will be hard enough to just get the front wheels over a rock.. let alone get the rest of the truck over with only 2 wheels pushing. I think that a stampede CAN be used for crawling with a lot of work, but will still be inferior to a tlt or clod. If you dont want a tlt or clod, maybe your just looking to be different, at least get 4WD. I use my e-maxx... It has independent suspension, but you would be surprised what it can do.
Old 01-23-2007, 04:41 PM
tjarr001
so if you have a stamped how come you cant use the motor or esc or steering servo? cause i have a duratrax evader st and wanna make a crawler, but i was hopin i could use prety much everything but the frame (use trany, motor, reciver, servo, and esc)
Old 01-23-2007, 07:07 PM
dezfan
dezfan's Avatar
Well MAYBE if any of you knew anything about crawling, you would know that a 2WD Independent Suspension rig isn't the good basis for a crawler.
Were as the TLT IS the basis for about 95% of all 2.2 crawlers.
So I DID indeed help him!
Now for the NON crawlers who like to add their 3 cents, get a clue!
Old 01-23-2007, 09:07 PM
tjarr001
dang thats harsh man i was just askin a question
Old 01-23-2007, 11:43 PM
dezfan
dezfan's Avatar
ORIGINAL: tjarr001
Sorry, that was directed at a few of the post above your.
You more than likely can use the ESC.
The motor probably not as it will have to many RPM.
As for the servo, it too will probably be lacking in the torque needed for crawling.
Now, a 55t Integy lathe motor is really cheap as motors go ($16.00 - $24.00) and work extremely well.
For a steering servo, the Tower Pro MG955 servo, is rated at over 200 oz's. and runs about $25.00 on e-bay.
Need anything else, please PM me.
Old 01-24-2007, 09:53 AM
tjarr001
what about the reciver and trany?
Old 01-24-2007, 12:46 PM
dezfan
dezfan's Avatar
Those too should work fine for you!
Find yourself a TLT and a good chassis(SW2,XRC,Vertical Smile,ect.....) and your on your way.
Old 01-24-2007, 03:26 PM
tjarr001
sweet. im thinkin bout makin my own chassis. but i need like a layout or some dimentions to go by. i got some 1/8" sheets of steel at my house that i could cut but i gotta get an idea of measurments first.
Old 01-24-2007, 07:22 PM
dezfan
dezfan's Avatar
You could use the Stock TLT chassis as a base, or mod it and use it as well.
Not the best, but it will work to start w/.
Old 01-24-2007, 08:18 PM
lohocla
wrong thread
