RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
need help
Old 06-11-2007 | 01:16 PM
Default need help
my dad run wires throght the drop ceilings in hotels and large companies.most of the time i help so the other day i got the idea to make an mini rock crawler to run the wires for us. but i've never bilt one before i'm pretty good at building stuff basicly i need it small with good suspention it can't be to tall either.
got any ideas
Old 06-11-2007 | 01:29 PM
Default RE: need help
How small were you thinking?
Old 06-11-2007 | 02:20 PM
dezfan's Avatar
I RC18 is 4wd and fairly small, while not a crawler per say, but lock the diffs and you would have a small 4WD platform.
Old 06-11-2007 | 03:45 PM
You could also try to find a Nylint 1/18. They are cheap and can climb very well.
Old 06-11-2007 | 08:17 PM
The Real Dogman's Avatar
I've been remodeling offices for years and I had the same idea several years ago and found that a tamiya battle tank worked the best due to traction issues when you start running out several feet of cable it tends to get very heavy for a small rc vehicle. So the tank had gobs of torque and traction needed for the task, I had intended to install and small wireless camera but back then they were just too expensive, but the tank worked great!! Oh we did add alittle weight to tank for extra traction in those dusty areas. A wheeled vehicle just got to hung up too much and did quite have the traction and menuverability with the load of a cable behind it.
Good Luck and have fun in whatever you choose that works out for you!!
Old 06-11-2007 | 08:19 PM
dezfan's Avatar
ORIGINAL: The Real Dogman
Great idea!
Old 06-11-2007 | 08:50 PM
I didn't think about that. I don't think a small RC truck would be able to handle that wieght. Go for a tank!
Old 06-11-2007 | 09:56 PM
hands without shadows's Avatar
If you absolutely want to go with a car you can make it lay out thin rope or line or w/e which you can use to thread cable.
Old 06-12-2007 | 06:58 AM
what if i built a larger scale one would that be able handle the weight. we usualy run cat 5 and it can get pretty heavy somtimes.
the reason i dont want to use a tank is because i would like to start rock crawlin too. i have some ideas on how to build it i just need a little help.
