AXIAL Axle just arrived!!!!!
I just received my AX10 axles from RCP Crawlers. (AX30488) Unfortunately, 4 screws were missing from the kit. They hold the ring gear to the diff case. Since RCP Crawlers do not have a phone # on their website, I called Axial directly.
Paul, in customer service was very helpful and informed me that the manufacturer forgot to include them, but they had stapled a bag of the 4 missing screws to the kit bag. Apparently a few kits slipped by and he would mail them to me first thing tomorrow. [8D]
With that kind of service, they earned my future business!!!! As for RCP, well.....there are plenty of companies out there with phone numbers.
Once they are assembled, I'll let y'all know how it works out.
RE: AXIAL Axle just arrived!!!!!
is everything pretty stout? im considering a pair of axial axles for a "scalish" trail rig. whats the width from hex to hex if you dont mind?
I will measure that for you and reply, although with axial beadlocks mounted to them, i measured 155mm inside tire-inside tire, which may work out to be around 195mm hex-hex.
Recon out
Recon out
Yep, about 195 mm hex to hex.
I noticed the screws on my beadlocks were the same as the ones i am missing, so i assembled the axles tonight.
They are "clicky". No shims in these diffs, just real tight ring/pinion mesh. Anyone else have this problem?
TIA
Recon out
TIA
Recon out
MO
Grab a hold of pinion shaft w/ a set of pliers and give it a good pull, you need to set the bearing completely and the notchiness w/ go away.
ORIGINAL: dezfan
mahogany dreams, sorry, I dont know anything about other axles of this type although they seem to be well made. Once I get my rig running, I can let you know more.[8D]
Recon out
MO
The Axial axles seem to be in the "sweet spot" for crawling at the moment.
They are wider than the TLT axles and they have a smoother underside(nothing to catch on) and have better clearance. Plus they come locked already, not that locking the TLT axle is difficult.
At the same time, they are narrower than the WK axles which almost require a huge offset wheel to be competitive and require a servo mount (added expense) plus they need to be locked (the Axial spool is a drop in piece) which is another expense.
