Strange Battery Question
Would it be ok to use my lipo battery from my blade cx2 untill i order a lipo? It is a 2cell 800mah Lipo. i would just cut off the normal plug and solder on a deans plug, but leave the charging one so i can still use the balancing charger that came with the blade. Thanks for any help.
RE: Strange Battery Question
Ok thank you, I dont know much about batteries. Which lipo do you recommend? I looked on maxamps .com but dont know which one to get. I just want a lipo so i can mount it on the front axle. or should i just get a regular split pack? Thanks for any help
Im Not worried about that ive read some stuff on that and im not completly retarded im sure i can fugure it out. I just need to find a good spot to read up on them and how and what chargers to use
AB, CANADA
http://home.comcast.net/~truerc/
This should help you out, if not check:
http://www.rchelimag.com/pages/howto...owto=18&page=1
