Axial Scale Project Questions
ID
Im going to try and get a scale trail rig up and going and i need to know of which setups i have would be best.
First: Axial AX10 Scorpion Kit
Mud slingers x4 2.2mm $50
Axial-10 Kit Assembled $220
Novak fifty five Motor$24
X-Trail Kit+hardware $65
Hitec 645mg $29
Tekin Hotwire 1450 $39
$427
Second: Axial AX10 Scorpion RTR
Axial AX10 Scorpion RTR $260
Novak fifty five Motor $24
Chassis Kit+ hardware $65
$399
Now i know i would need some internal shocks. Also the RTR setup would give me some extra parts. Really the only reason i wanted to go RTR is it is assembled. Now that sounds bad as i am going to convert to the x-trail anyway, but i am new to this and would like to get an idea where everything goes so its a bit more easy to put it back together. Otherwise are the parts i selected decent for a beginner trail rig?
Hitec 645mg $29
$427
$399
PA
RE: Axial Scale Project Questions
Well with what you've got posted here right now it makes more sense to spend the extra $27 and get the kit. However you're not figuring in the price of a radio which is also included with the RTR. If you have no intentions of using the RTR radio then by all means get the kit. Otherwise figure in another $40-$50 to get an equal radio to what comes with the RTR (or more for a better one if you like).
Also, you wrote 2.2mm tires. Do you mean 2.2 inch tires? I think you should really start looking around on the various scale crawler forums and see what size you prefer. Most people are going with 1.9" tires because they look much more scale, and more easily clear the body under articulation on a scale truck. On the other hand 2.2" tires will enable you to crawl better just because they are larger.
I'm sitting right around $210 so far with my scale ax10 crawler.
AX10 Axles[2] 1.9
Ax10 Trans
Hpi Gunmetal rims 1.9
Novak 55t $160 from Tower
RockStompers $50 From CKRC
Bruiser Body
Leaf springs Had for a long time,was going to use the Bruiser frame [sold] but decided to make my own. V2 Skala chassis.
Older Assosiated shocks Also had a long time.Still need to aqiure the rest of my elects.I may go Brushless and move the Novak 55t[x2] to my Clod Crawler build.Going to use 2.2 MudSlingers on it.
http://offroader5.freeservers.com/templates.html chassis link check out the V2Skala
AX10 Axles[2] 1.9
Ax10 Trans
Bruiser Body
ID
Yea i meant 2.2 Inch, and ya i would rather have the 1.9s but the price on bead locks for these is crazy. I Could do the gluing but i think the bead locks look alot better. I dont know yet still up in the air, also this is the chassis i was looking to use..http://i68.photobucket.com/albums/i2...2/jeepbods.jpg the guy is selling it for $35, i think it has potential.
