RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
ESC
Old 12-14-2008 | 11:05 PM
Default ESC
Anyone running an 8 cell pack on a Novak Rooster ESC? I know the ESC says a 7 cell max but have heard of people running an 8 cell and no issues.
Old 12-15-2008 | 03:13 PM
K_B's Avatar
K_B
Default RE: ESC
Generally speaking, companies list a maximum number of cells for a reason. If you're feeling lucky, then go for it. It probably will work, but it will generate more heat. More heat is detrimental to the lifespan of the ESC. In other words, if you run 8 cells, don't expect the ESC to last for very long.
If you wanna run more cells, I would suggest using a Castle Sidewinder. Not only does it handle more voltage, it also runs brushed and brushless motors.
