RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
servo help
Old 03-07-2009 | 11:55 PM
Default servo help
wondering what is a good servo to use on my ax10? I've had it for a little over a year and replaced the stock servo with a futaba s3305 when the stock gears wore out on the first day. JUNK servo. The futaba is starting to get weak and not turn when bounded. Any sugg. would be great.
Old 03-11-2009 | 05:47 AM
Default RE: servo help
This servo is pretty decent......Hitec HS-5645MG Digital High Torque Metal Gear BB Servo......$48.00 at Tower....!!! Have a good one..!!
Old 03-11-2009 | 09:26 AM
hitec 645MG, 133oz in @6V
http://www3.towerhobbies.com/cgi-bin...&I=LXUZ89&P=ML
hobbico CS-170, 333 oz in @6V (but three times as much $$)
http://www3.towerhobbies.com/cgi-bin...&I=LXNRN6&P=ML
are you running a BEC at 6 volts? this will drastically improve your servo performance.
Old 03-11-2009 | 12:50 PM
grimgard's Avatar
ORIGINAL: smity80
Servo getting weak? never heard of that. Are you using the stock axial ESC? if so then that is the problem not your servo. The stock ESc does not give enough power for the servo and motor when bound up.
Old 03-13-2009 | 11:07 PM
I was wondering if it was the esc. It is the stock still what esc would you suggest i use? Is it not putting out enough
