My RS10 Build
CA
My RS10 Build
well.. i dont have it yet.. it will be here on friday.. but heres the body im going to use.. its from the toy grade newbright rock crawler and i removed alot of plastic.. just waiting for my rc..
i will keep you guys posted
PA
RE: My RS10 Build
Several parts from the Axials work like, bent lowers, high clearance steering set up, any wheels that say they will fit axial and aluminum knuckles. I also made a battery tray to run normal 6 cell stick pack slightly move towards the front. I made a custom aluminum reciever/esc tray and lowered it to help lower the CG. Im also working on a way to get rid of the bat wing upper suspension mount and just run a normal style set up but I havent quite got it figured out where I like it yet.
RE: My RS10 Build
There's a whole thread I created over on rccrawler's forums about the RS10's. Has plenty of info about mods and some pictures of my rig and some others for references. Let me know if you have any questions. Here's the link:
http://www.rccrawler.com/forum/showthread.php?t=203627
PA
RE: My RS10 Build
I just got my new one today too. I put my other wheels and tires on, hacked up the body for more clearance, made the delrin skid and now its torn apart awaiting the rest of the parts to come.
CA
RE: My RS10 Build
update on my build.. i got bored and mounted my nb jeep body on.. but i dont know if im going to keep it on.. and i just order axial beadlocks and losi rock claw tires and wheel weights.. heres a pic soo far
PA
RE: My RS10 Build
Yes the Axial rings fit RS10 and RS10 rings fit Axial. Th nice thing about the RS10 rings is the bolts are counter sunk so they wont get caught on the rocks.
CA
RE: My RS10 Build
heres an update.. got new foams for tires... lowered and cut body, painted the beadlocks, hitec hi-torque servo in front. and trimmed down the steering stop on front and rear.. for more steering radius..
let me know what you guys think..
CA
RE: My RS10 Build
heres my new servo.. Hitec Hs-645MG Ultra Torque. after i installed it i found out that my steering arms were gunna snap!.. soo i removed it and re-installed the stock one..
in a couple days im going to order the CKRC Aluminum knuckles for my front steering.. then ill be good to go!
PA
RE: My RS10 Build
Look at my last post in the link below. Its all about the CKRC high steering knuckles.
http://www.rccrawler.com/forum/showt...203627&page=12
