Waterproof Rock Crawler
CA
I'm exciting to get an Axial Scorpion Rock Crawler. I have ordered online and waiting to deliver in my house. I wonder if my rock crawler is waterproof? Can I ride in the mud, pond, or shallowed river? I've read something in the forum that a silicon paste can seal the electronic parts from water. Any advice would be greatly appreciated...
RE: Waterproof Rock Crawler
nothing on your truck is waterproof..
id suggest plasti dipping your servo. just go buy this - http://www.whitenoiseaudio.com/blog/...300-786251.jpg
and do this with your servo - http://www.societyofrobots.com/image...plastidip2.jpg
then you can peel the stuff off around your servo horn area
for your esc, i would suggest a 35t or 45t motor to make sure the esc doesnt get hot then, take a old brush and wipe the plasti dip stuff all around the esc, and before you do that id actually fill the esc up with dielectrical greese.then coat the outside with plasti dip
as for your rx, take a baloon, put the rx in a baloon, zip tie the opening closed on the baloon then fill the closed opening with dielectrical grease..
and for your motor, theres nothing you can do except keep it clean and lubed
