Which set up would be best to go for?
My Feedback: (42)
VA
I am looking at two different crawlers to trade for. What are you opinions?
Crawler #1
AX10 based
SWX Chassis
Novak Rooster w/ 55t motor
cc BEC
MIP rear driveshaft
HD lockers
DNA dig
Hitec 7955 steering / Hitec 645mg for dig
rover white dot tires
3 set of wheels tho none are fancy
4 2s lipos 800mah in parelell to double mah
Crawler #2
AX10 based
SWX Chassis
VP dig
RJ ds8711 steering servo, hs645 dig servo
Tekin FXR esc w/ Tekin 35t handwound motor
Aall steel trans gears
MIP driveshafts,
STRC lockouts,
Aluminum big bore shocks
Panther tires and a set of rovers
4 lipo batterys
Losi grappler body.
Crawler #1
AX10 based
SWX Chassis
cc BEC
MIP rear driveshaft
HD lockers
DNA dig
Crawler #2
AX10 based
SWX Chassis
VP dig
MIP driveshafts,
STRC lockouts,
4 lipo batterys
Losi grappler body.
RE: Which set up would be best to go for?
If it's the VP Hurtz dig unit, that's a better dig unit I think. The ESC is also nicer; does 3S lipo. 35T motor is more versatile than the 55T.
TX
I agree. Crawler #2 sounds like the better of the two choices. Panther tires are really good, Vanquish products are great and I've personally had many problems in the past with Novak systems. Tekin is supposed to be really good in a crawler. Plus, the extra wheel speed from a 35t motor will help you get through/over tough obstacles, especially if you can run 3s LiPo.
Good Luck!
Good Luck!
