Problems with highlift
Well i have the hilux and installed the junfac 4link setup and have issues. My front end has horrible side to side axel movement. I think this is due to the junfac kit having no articulation. Do you thing this would help up front with this issue?
http://www.rc4wdstore.com/2/product_...roducts_id=501
IL
RE: Problems with highlift
Maybe, but before you buy that check the upper links to make sure that they are properly installed. The upper links in most 4 link systems control the left to right movement of the axles. If there is a lot of sideways movement, most likely it is either the upper links are improperly installed or there is not enough angle to them in the system.
Yup. You need triangulation to keep the axle centered. In other words, the top links should form a "V" going from the chassis and meeting at the center of the axle.
