RCU Forums
-   RC Rock Crawlers (https://www.rcuniverse.com/forum/rc-rock-crawlers-277/)
-   -   building a crawler need help (https://www.rcuniverse.com/forum/rc-rock-crawlers-277/5475065-building-crawler-need-help.html)
DirftTech 02-25-2007 09:34 PM
I am building a rock crawler and I have a few questions 1) can you use the EX-10 Helios 3rd channel radio for rear wheel steering? and 2) can you compine 2 ESC's BEC so you can have two times the current? thats it for now thanks for the help.
5150bronco 03-07-2007 06:42 PM
RE: building a crawler need help
You do need a 3 channel, go with the tq3 setup, by making your own switch for rear steer. Look on rccrawler for more info.
ASSOCIATED_DRIVER 03-07-2007 11:57 PM
If the 3rd channel is also linear proportional then you can use it. It would not work if its only 2 position. You can use the same channel for your front steering to control another servo for the rear steering. You will need a Y splitter servo cable. This will control both front and rear at the same time. You can set it up so the tires all point at the same direction, or both front opposite both rear.
Dont quite understand your 2nd question. Are you planning to run 2 motors?
