Go Back  RCU Forums > RC Boats > RC Sailboats
 Waterproofing .. ? >
Waterproofing .. ?
RC Sailboats For all your r/c sailing needs, post here.
Waterproofing .. ?
Old 10-15-2003 | 11:39 PM
Default Waterproofing .. ?
What is the best way to keep the switches and receiver + battery from getting wet during sailing? I am more worried about the switch as it is installed on the boat and will be the first item to catch on some water ?
thanks in advance
Old 10-19-2003 | 01:18 PM
ballgunner 's Avatar
Default RE: Waterproofing .. ?
The best way I've found yet is to have a water tight hull and hatches. If you have dusty bilges the electronics will not be a problem. Some cover them with balloons and condoms. Electronics in use generate heat and will deteriorate when too much is generated. I leave mine in the open. One advantage over RC aircraft is that there is little if any vibration that has to be dampened with foam rubber.
Old 11-04-2003 | 09:41 PM
Batteries don't seem to mind getting wet once in a while. Rx and switch should be mounted under the deck (velcro). Connections can be coated with silicon (Radio Shack, in a tube). On windy days, tape the hatch cover.
Old 11-05-2003 | 10:58 PM
There's also a very handy DiElectirc Waterproofing material you can use, I've dipped my RX, Servos, and switches in it and they work fine. Batteries in a balloon stay pretty dry. The waterproofing stuff is AeroPlate. It's linked from the AMYA Suppliers listing pages.
Just follow the instructions and it works great.
