Northwind 36
#326
RE: Northwind 36
ORIGINAL: Sailingkid
Has anyone thought about adding say 300mm to the top of a northwinds mast then using a really big mast crane top put on a lot more sail area? i reckon they would fly like that!
Otherwise, you'll either have the bow diving going downwind or the boat tilting a lot when going upwind...
Anyway, try it and give some feedback.
#327
RE: Northwind 36
The NW36 is in the 36-600 class which if raced in class is limited to 600 square inches of sail area. There is an optimum hight for a mast, and the NW36's is already pretty high. The rig on the boat as it comes out of the box is pretty basic and quite dated. I've mentioned the limitations of the design in earlier posts on this thread, but if it was to be re-desiged with the modern philosophy, the mast would probably be a little higher, the mainsail would have a higher aspect ratio (be taller and thinner in otherwords) and have a square top, and the jib will be a bit smaller and have a higher aspect ratio as well.
How would this help? Well, the higher aspect ratios will give a bit more power with less aerodynamic drag and the square top will allow the sail to relase power without affecting performance too much. This works because as the mainsheet is eased, the wind blows the top of the sail open first thus releasing the power from the top of the sail keeping the bottom of the sail powered up. This means the boat has less heel when sailing close to the wind and it will go faster. To see what I mean, have a look at Midget's first photo. His NW36 is sailing almot the same tack as the other boats but is heeled much more. The boats behind have more sail area at the top and have opened out there because the helm has eased the mainsheet. Now, these are a different design and the NW36 isn't allowed a sail such as these boats due to the class maximum roach of 2 1/2". However, a max allowable roach when measured perpendicular to the leach at the head of the sail will allow some 'squareness' and with a straight leach, will allow more control than currently afforded.
Sorry Midget, it's not a criticism of your new sail, in fact your boat looks fantastic.
To see what a modern sail looks like, google for this year's Amercias cup boats and have a look at their rigs.
#328
RE: Northwind 36
ORIGINAL: cat sailor
[...]the square top will allow the sail to relase power without affecting performance too much. This works because as the mainsheet is eased, the wind blows the top of the sail open first thus releasing the power from the top of the sail keeping the bottom of the sail powered up.
The "square" top of the mainsail can't be connected to the mast crane, otherwise that effect you described simply won't happen.
#329
RE: Northwind 36
No, the top isn't connected to the crane. It's held in it's square shape by bracing from battens. My full size boats both have square top sails and they have the square held out by a batten which points up from the horizontal by about 30 degrees as well as having stiifer material at the top of the sail. I plan to make such a sail for mine from mylar (when I eventually find the time) which will have the top re-inforced with either a double or triple thickness, or cloth tape.
#330
RE: Northwind 36
yes i think that you would need to take the masthead crane off and build a longer one, and as long as you built the sail so that it flags the top upwind and sets downwind i think ud be fine.[8D]
#331
RE: Northwind 36
I don't Think extending the mast 300mm will help.
It will make the yacht go faster in light wind, but in heavy it will be way to much.
I say this because When i sailed my northwind against some Storm 100's, For starters the storm
100 is 1m long (Northwind 36 is 90cm), Also the storm 100 has a mast high of 100cm (Northwind 123cm).
Im not sure how much the storm 100 ways compared to the northwind, But i can tell you the storm is a lot heaver.
So anyways, I noticed that when a gust of wind hit my nortwind it would just heal over, until
I let the sails out a bit, Mean while a gust hits the storm 100, doesn't heal over and just powers on past me.
I think this is because of 2 reasons, the sails are to tall, or the lead weight is to light.
I'm not sure what winds you sail your northwinds in, But I would think about changing the shape of the
northwinds Main sail.
The First pic is the shape of sail im thinking of, because the standard sail in my opinion spills wind very low to
the boom. This is ok in heavy winds, but not so good in light.
The second pic is just comparing the to boats on the same tack, same wind gust, just the northwind leaning a hell
of a lot more than the storm 100.
But this is just my opinion, By all means make the mast taller
#332
BC, CANADA
RE: Northwind 36
I just checked mine over and charging the electronics.I have 2 of them,one for the Girlfriend.We never used them at all this year,but now the weather is lousy and blustery.Cant wait to get them on the water again [8D]
#333
BC, CANADA
RE: Northwind 36
Had a good time with it,but I think my sails are sloppy and the Sail angle seems too much at midstick.
I had some very strong gusts,I almost had the sail in the water.I find that the nose digs in when running agressive,its still above water,is there a way to get the rear to run deeper?
#334
RE: Northwind 36
Hi
I've had the bow of my NW go competely under the water when running down wind in a strong wind,I think it has to do with exeding the maximium hull speed the boat just won't go any faster so the bow is forced down.
As to the boat heeling over so far that the sails are in the water ,When mine gets to about 45 degree's I let the sail's out a bit and the boat straighten's up.
Bob
Bob
#335
BC, CANADA
RE: Northwind 36
Dang,so I am exceeding the boats limits [X(]
I guess it wont plane like a power boat?
I like it when it gets rough out here,we've got plenty of lakes and stormy weather most times of the year.
I would love a boat that take some punishment and sail in rough conditions.
I looked at the Avalon 44 by Victor models,is it worthy? Anything else a bit bigger and performance oriented?
#336
RE: Northwind 36
I need help. I just took my boat out for one of the first sails and i forgot to tighten the nut down on the rudder post. The rudder is now on the bottom of my lake and i have no idea where to get a new rudder. apparently the northwind as been discontinued??? Any ideas are welcome-alan
#339
ON, CANADA
RE: Northwind 36
Hey hey guys, its been about a year since i bought my NW kit, and only really now ive gotten much progress on it :P Still needing to be completed are my radio gear stand and finally sail rigging.
Do you guys have a secret to storing the rig when transporting? From what i can see completely detaching the mainsail from the mast would take alot of time and effort, that would probably result in my breaking something off of it.. same goes for splitting the mast sections
Anyway heres my new paint job.. she still needs a name, any suggestions?
#341
RE: Northwind 36
Hey Guys, After reading most of this thread I have come to the concluion that your all nuts. I can see why though. Ive had my NW for about 4ish years now and Its a lot of fun and a great way to waste time. There are 5 of us where I live who have NW's. They are all set up on different channels so we can have evenly matched regattas with the same specifications. They are all custom painted so you can tell them apart in the distance. I live by the ocean and we sail in the harbour and as long as we wash them down afterwards, the salt water doesn't matter. I happened to stumble across this thread after I was looking at ways to fix a couple of things on my yatch. and I found all the answers here and It looks as though I'll be busy for a while. Thanx Guys from Victoria Australia
#342
RE: Northwind 36
Hello all!
This is my first post here in this Forum. I live in Portugal and I'm a personal friend of pjesus (yellow Java). I have a Northwind 36 that I decided, a few year ago, to upgrade and transform.
Here I'm sending some pictures of the "new" Northwind MAXIMUS.
The "interiors" mounted on carbon fibre.
Some handmade deck fittings and bowsies.
Carbon reinforcment to support higher mast tension.
New carbon mast crane
The electronics in place and a carbon shelf to hold battery box.
With the first set of molded sails.
I hope you liked Maximus.
#344
RE: Northwind 36
Hi bobsir
Thanks for your words.
The sails are homemade. I used a program named sailcut4 to cut the pannels and then I mounted the sails over a homemade mould.
#345
RE: Northwind 36
ORIGINAL: lmbp
#349
IL
RE: Northwind 36
You guys have done some nice work. I just finished painting my first RC Sailboat, it's the Northwind 28.
I've seen all the custom work done on the sail servos. I was wondering if the servo arm seems to be such an issue, has anyone considered converting to a winch servo? Can that be done? Any thoughts on the pros & cons?
I'll try to post pics soon.
thx
ZRYDE
thx
ZRYDE
#350
FL
