Aussie 2 construction
OK, been doing static models for over 14 years, RC only in the last 3 months. Currently I have a propulse buggy, a proboat mini v racer, and now an unassembled Aussie 2.
What all is involved in the construction process, and what are some tips you guys can share to skip common beginner problems? I know the Aussie is small for sailing, but I have a very limited ammount of water,(shallow,) ti use on a small pond, so it's the perfect size.
The Aussie II is a nice boat.
Once you've assembled and sailed it, you'll realize the sails are not the best, as is the case in most RTR sailboats, and the rigging has room for improvement aswell.
Regards, Jan.
Regards, Jan.
OK, so here's where I'm at:
BODY: All servos/electronis are installed. The rudder was interesting, as there was no direct locking mechanism and the instructions indicated a removable rudder for swapping purposes,(one for function, one for display,). This disturbed me, I don't want to lose a rudder in deep water. SO after making sure theres clearance, I add a small ammount of glue to the inside bottom connectin gthe rudder to the servo arm connection, and a drop of glue to the top, where I had drilled a tiny hole to allow a thin piece of extra wire to be slid through. I plan on trimming it down and braiding it in place. I hope this will hold it securely in case of the unforseen. I also plan on injecting the rudder inlet tube with lithium grease,(proboat series, same as they use on their prop drive shafts,) to help with water resistance and lubrication. If anyone thinks this is a bad idea, please inform.
TOP DECK: Most of the plastic fittings and details are already glued in place and trimemd down. The helm section is also nearly complete, all pieces are glued or bent into place,(wire etc.,).
Its staring to look like a real boat...
I'll see if my fiancee can take pics, its her camera and an expensive one, and I don't want to screw it up. When I can, I'll try to get them posted.
The suggested fixing for the servos is optimistic. The plate that the instructions say you should tape them to can be removed and holes drilled for metal straps to connect into, and replaced.
As is common with this class of kit, the sails are not the best, and the booms would be better made of something rigid. A kicking strap would help, as well. Good fun at the price, though.
Considering that when sailing, rigging will wrap itself around anything it can, I left most of the ornamental deck fittings off.
