Go Back  RCU Forums > RC Boats > RC Sailboats
 Increased servo rotation >
RC Sailboats For all your r/c sailing needs, post here.
Old 08-09-2007 | 01:15 PM
Default Increased servo rotation
Have an old Futaba s125 servo. I would like to use this in my Northwind 36 which I am building now. Is there a way to increase the rotation of the arm to about 180dgrees?? Or am I better off buying a new servo. PLEASE HELP
Old 08-09-2007 | 05:15 PM
Default RE: Increased servo rotation
I modified a couple of Hitec servos by adding resistors to the pot to get more movement.
I also tried a servo stretcher with a servo that was hard to modify.
http://www.servocity.com/html/180o_servo_stretcher.html
Old 08-11-2007 | 08:44 PM
Perhaps this thread will help.
http://www.rcgroups.com/forums/showthread.php?t=712322
Old 08-23-2007 | 01:03 AM
Do you think this procedure ( stated in the links above) will work on a hitec 755 1'4 scale servo...seems easy to do anyway.
Tatolazo
Old 08-23-2007 | 06:41 AM
The only difference should be that you have more room to mount the resistors - the end of the circuit that you intend working on should be identical to its little cousin.
