Crimping sleeve orientation?
My Feedback: (10)
ON, CANADA
I am crimping the rigging on my Aviatik DI with the BUSA crimping tool and sleeves. I am wondering if the oval should be crimped "flat", which flattens it further, or if it should be crimped "on edge" so that the resultant crimp is closer to a cylinder.
Thanks in advance,
Martin
Thanks in advance,
Martin
Banned
RE: Crimping sleeve orientation?
When crimping fishing lines, and aircraft rigging, I like to crimp near one end in one direction, rotate the sleeve 90 degrees and crimp the other end. Never lost a fish, nor an airplane due to slipping lines.
Les
Les
Sounds like BUSA did not send instructions with the tool. Try this link - it should give you a PDF for instructions. It is meant for a different tool, but the application is very similar. http://l-36.com/manuals/Nico-Press-Tool.pdf
Hello Martin,
please look at the homepage of Toni Clarke.
Toni Clarke has a company in Germany for 1/3 - 1/4 models and accessories, ....WW1 Pup and so on.
Catalogue side 115 is all for the rigging and he writes:
http://www.toni-clark.com/
Ido it also and I have no problems but you can call him, he's a very good guy and was born in great britain.
If you need something for 1/4 scale models, than you can get it at him.
greetings gabriel
Crimping Sleeves for Nylon covered Wire
greetings gabriel
My Feedback: (10)
ON, CANADA
Thanks guys. I've tried the "on edge" method and it seems to work fine. With the 1/32" sleeves, my crimper compresses the entire sleeve rather than just a portion so that three crimps per sleeve can't happen. I'll take it with me to Rhinebeck this weekend and talk to the BUSA folks there.
Martin
Martin
