Reload this Page >
1/4 Scale Stinson Reliant
Old 05-14-2012, 11:50 AM
TKFOKKER
Default 1/4 Scale Stinson Reliant
This Model was scratch built from Wendell Hostetlers Plans. It has a 126 inch wing span, is 83" long, and has a wing area of 2310 sq. in. She tops out at around 48 lbs. and runs of a 5.8 cubic inch, swinging a 28-10
The finish paint scheme is the 1930's Civil Aeronautics Authority. The CAA is what the FAA is today. The colors were black and yellow, very striking color scheme.
The story behind this build is that 16 years ago I aquired this model already started. The fuselage was 60% complete as far as the framing is concerned. The wings were started as was the tail. There was a tremendous amount of work yet to be done. I put the plane up in storage and basically forgot about it. Last June I brought here out and took a good look at the plane relizing that alot had to be changed and fixed and built yet. I wanted something new for Rhinebeck so I went at it full steam. I worked on the model almost every day for three months. nights and weekends. I had decided to paint the plane in the colors I wanted, Black and yellow, I did not even relize there were Reliants out there in those colors. One day sitting on the throne reading one of my 1930's Flying magazines I came across one picture of two stinsons side by side in black and yellow!!! I was blown away. I found my color scheme. I still have much left for detailing, the cockpit has yet to be done, and she only has one flight on her. I did the test flight at RHINEBECK AERODROME. I was actually still painting it the day before I left for the Jamboree. This is my second WH stinson, I built one years ago only to loose it on the third flight from bad batteries. I used some of the parts of of that airplane.
TK
ID:	1762646   Click image for larger version
ID:	1762647   Click image for larger version
Old 05-14-2012, 11:59 AM
TKFOKKER
Default RE: 1/4 Scale Stinson Reliant
This is where I started to document the build. As you can see I used a small plastic model to get my details. Here I have already completed the tail feathers and have worked my tail wheel from my first stinson into this one. I also used all my door hardware from the first one. The whole top of the model was not built including the windsheild structure. All fiberglass was purchased from Fiberglass speicialties.
TK
ID:	1762649   Click image for larger version
ID:	1762650   Click image for larger version
ID:	1762651   Click image for larger version
ID:	1762652   Click image for larger version
ID:	1762653   Click image for larger version
ID:	1762654   Click image for larger version
Old 05-14-2012, 12:04 PM
TKFOKKER
Here are some more pic's. I also was able to use all my old struts from the first one. I have a lot of pictures of my first stinson, but they are not on the computer I will copy them so I can post them later.
TK
ID:	1762657   Click image for larger version
ID:	1762658   Click image for larger version
ID:	1762659   Click image for larger version
ID:	1762660   Click image for larger version
ID:	1762661   Click image for larger version
ID:	1762662   Click image for larger version
ID:	1762663   Click image for larger version
Old 05-14-2012, 12:31 PM
FlyerInOKC
FlyerInOKC's Avatar
Subscribed! I can't wait to see how it comes out!
Old 05-14-2012, 01:00 PM
wings2an3
wings2an3's Avatar
Tom,
It seems that we like alot of the same type of planes, hopefully family plans don't get in the way of Rhinebeck this year would like to talk in person.
ID:	1762689   Click image for larger version
ID:	1762690   Click image for larger version
ID:	1762691   Click image for larger version
Old 05-14-2012, 01:47 PM
TKFOKKER
Wings2an3
Nice stinson, is it a W.H.? Thanks for posting it! Ya I'm all about WW-1 and the golden age stuff. I do like WW-2 trainers also.
TK
Old 05-14-2012, 03:55 PM
wings2an3
wings2an3's Avatar
Yes, it is a WH 1/4 scale.
Old 05-16-2012, 04:39 PM
TKFOKKER
This is my wife helping me to decide on which cowl to use!! She'd kill me If she knew I posted this!! This is the brisson 5.8 I'm using.
TK
ID:	1763262   Click image for larger version
ID:	1763263   Click image for larger version
ID:	1763264   Click image for larger version
ID:	1763265   Click image for larger version
Old 05-16-2012, 04:43 PM
TKFOKKER
Here I am fitting the cowl ring, cowl, and dummy engine. And all the steel mounting.
TK
ID:	1763268   Click image for larger version
ID:	1763269   Click image for larger version
ID:	1763270   Click image for larger version
ID:	1763271   Click image for larger version
ID:	1763272   Click image for larger version
Old 05-17-2012, 03:40 PM
TKFOKKER
Some thing needs to be done about this web site, I'm still having trouble uploading pictures. Plus I can't find anywhere on the site where you can contact anyone to talk about this problem. Does anyone have any ideas ?
TK
Old 05-17-2012, 04:46 PM
abufletcher
abufletcher's Avatar
You can try contacting RCU-Admin:
http://www.rcuniverse.com/community/...m=1&memid=6254
But good luck getting anything done, given how persistent this problem has been for well over a year.
Old 05-17-2012, 07:07 PM
alltumbs
Don't ever let her see you posted that picture ......... Or the sopranos will have a new meaning to you.
Old 05-18-2012, 02:45 AM
TKFOKKER
I Like that show!
|Wow Pic's came through. Here are the dummy engine mounts made from steel. also fitted the cowl.
TK
ID:	1763591   Click image for larger version
ID:	1763592   Click image for larger version
ID:	1763593   Click image for larger version
ID:	1763594   Click image for larger version
ID:	1763595   Click image for larger version
Old 05-18-2012, 03:01 AM
TKFOKKER
More engine cowl shots, also I reused my old dash board from my first stinson. A little rough, but good enough. Just a fun scale plane.
TK
ID:	1763597   Click image for larger version
ID:	1763598   Click image for larger version
ID:	1763599   Click image for larger version
ID:	1763600   Click image for larger version
Old 05-18-2012, 11:04 AM
alltumbs
No TK, I'm talking about hitting those "really high notes"
Jim
Old 05-18-2012, 03:57 PM
TKFOKKER
Started to cover fuselage in these pic's. I used sig coverall and polycrylon for sealant.
TK
ID:	1763824   Click image for larger version
ID:	1763825   Click image for larger version
ID:	1763826   Click image for larger version
ID:	1763827   Click image for larger version
ID:	1763828   Click image for larger version
Old 05-22-2012, 06:50 PM
TKFOKKER
Finished up the covering on the fuselage in these photo's. Started appling the metal panels.
TK
ID:	1765143   Click image for larger version
ID:	1765144   Click image for larger version
ID:	1765145   Click image for larger version
ID:	1765146   Click image for larger version
ID:	1765147   Click image for larger version
Old 05-25-2012, 03:28 AM
TKFOKKER
More front metal work and wind sheild being applied.
TK
ID:	1765656   Click image for larger version
ID:	1765657   Click image for larger version
ID:	1765658   Click image for larger version
ID:	1765659   Click image for larger version
ID:	1765660   Click image for larger version
Old 05-25-2012, 03:32 AM
TKFOKKER
Finished up metal work.
ID:	1765662   Click image for larger version
ID:	1765663   Click image for larger version
ID:	1765664   Click image for larger version
ID:	1765665   Click image for larger version
Old 05-25-2012, 02:34 PM
wings2an3
wings2an3's Avatar
Tom,
Your building is an inspiration and fantastic.
What is the material used to make the skins and any special technique.
Jay
Old 05-29-2012, 11:33 AM
TKFOKKER
Here I hve fitted the wing struts which will be covered with wood, they are made from aluminum. Also I am getting the wings finished up ready for covering.
TK
ID:	1767040   Click image for larger version
ID:	1767041   Click image for larger version
ID:	1767042   Click image for larger version
ID:	1767043   Click image for larger version
Old 05-29-2012, 05:41 PM
TKFOKKER
In these photo's I have covered the wings and all tail surfaces. I used Polycrylic for my sealant, first time. I think the second time around I'll do better.
TK
ID:	1767165   Click image for larger version
ID:	1767166   Click image for larger version
ID:	1767167   Click image for larger version
ID:	1767168   Click image for larger version
ID:	1767169   Click image for larger version
Old 05-29-2012, 05:51 PM
abufletcher
What will you use as the final fuel-proof coat(s) over the polycrylic?
Old 05-30-2012, 03:17 AM
TKFOKKER
Abu
This model to me is just a fun scale flier, so the finish had to be cheap and quick. Krylon was used on the whole plane. |I will show all the process coming up.
TK
Old 05-30-2012, 03:24 AM
TKFOKKER
A few photo's showing the rib tapes and glue style stiching. Also started priming the fuse and have painted the tail. I used krylon flat white under the yellow, only after I discovered the gray was too dark and difficult to cover with the yellow. I'm not used to using these types of finishes on a model for I have mostly used Dope for finishing, and latex house paint.
TK
ID:	1767256   Click image for larger version
ID:	1767257   Click image for larger version
ID:	1767258   Click image for larger version
ID:	1767259   Click image for larger version
ID:	1767260   Click image for larger version
