How to...
Hi scale modeller,
I'm finisching a GP spitfire, and my target is paint all frame to learn about scale finish.
I have covered my model whit alluminun monokote, and now I want paint over.
My color choice are the following:
- humbrol enamel (perfect for FS standard)
- nitro spray can (I do not know if some color exist)
what is the best choice?
Then I must fuel proof all model. I have a epoxy trasparent paint, but ny doubt is that the color paint do not work well over monokote.
Anyone have painted a monokote covered model?
Alessandro
Alessandro
Hi hircflyer,
I'm very interested about this article. Can you scan for me the pages with mookote paint tips?
I'm unable to find MAN [>:] in my country.
Thank you
Alessandro
Thank you
Alessandro
PA
I've repaired a badly damaged balsa cowl. Work required use of wood filler and, of course, a lot of sanding. It's time for Monokote now. Do I need to put a thin coating of something on this before I attempt to get the Monokote to adhere? If so, what and what else should I do?
Thanks, in advance, for your help!
ggogmo
ggogmo
For painting MonoKote or any film covering.
1. Scuff the surface with 0000 steel wool OR the green pot scrubbing pads. Be careful you do not go through the covering on the "high points" - ribs, etc.
2. What you want is a "frosted" appearance on the covering.
3. THOROUGHLY clean the area(s) with rubbing alcohol or denatured alcohol.
4. Prime
5. Mask and paint.
6. If the paint is not fuel proof, clear coat it. I have found the water base polyurethane is definitely fuel proof to 10% nitro and several reports indicate it is good to 15% nitro.
For ggogmo
You do not need to put anything on the cowl before applying the MonoKote, although many people would suggest a coat of BalsaRite over the cowl.
I have a suggestion which may be easier in the long run. Why not paint the cowl ? Bring a sample of the color you need and have it matched in latex paint (about $10 a quart ). Put a coat of sanding sealer on the cowl, sand, then prime. Spray your latex and let it "cure" - typically 7 - 10 days, then clear coat with a water base polyurethane to fuel proof it. There are several threads here on painting with latex.
4. Prime
5. Mask and paint.
For ggogmo
PA
Thank you for your answer and particularly the suggestion to "paint" instead of using MonoKote. I certainly like the "painting" idea, since I am having some difficulty forming the rounded shape of the cowl so the monocoat will lie smoothly.
Mike
Mike
